help fuel problems help
Old Jun 16, 2010 | 02:02 PM
COBRACON666's Avatar
5point oh no
Default help fuel problems help
ok so here we go i have an 87 mustang 5.0 with efi . it starts up fine idles good once i drive for a bit it chokes out like it has no gas. i go to the schrader valve and check to see if there is fuel pressure and there is BUT its way too much the gas is almost boiling hot and there is alot of air in the line. i bleed all the pressure out of the fuel line and it fires right up few minutes later it will die and i bleed out the pressure and it fires right back up. any thought or ideas are appriciated
Old Jun 16, 2010 | 05:51 PM
GNs-r-slow's Avatar
Bondsman
sounds like your return line is restricted.
Old Jun 16, 2010 | 06:57 PM
bvh's Avatar
bvh
put a carb on it?
Old Jun 16, 2010 | 07:22 PM
95coBraSVT's Avatar
banana republic
Originally Posted by bvh
put a carb on it?
WIN! LOL FP regulator no good?
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Jun 16, 2010 | 07:37 PM
GNs-r-slow's Avatar
Bondsman
This could be the culprit as well, but I would think it would be on the return side of the regulator.
O.P.
If you see no visual kinks in the return line (especially look at the rubber section) Put a gauge on it and that should tell the story before you buy any parts
Old Jun 16, 2010 | 07:41 PM
Tiffiny's Avatar
I can fix your bullshit
put more gas in it.....maybe
Old Jun 16, 2010 | 08:43 PM
Tony@1320Motorsports's Avatar
I agree with GNS... Your return line is being cutoff by something.
I would put my money on it being a vacum issue. When there is a drop in vacum the regulator closes the return line which gives you a boost in fuel. So it could be since there is low vacum the regulator is cutting off the return line so the fuel builds up in your fuel rails which is causing it to cook and get boiling hot and thats why when you check your schrader valve you have gallons of hot fuel coming out.
I would check out the vacum first if that just happens to be good then check out your regulator the spring in it probally got stuck and thats whats cutting of your return line and causing all your problems.
Hoped this helped! Let me know what happens!!
Old Jun 16, 2010 | 10:24 PM
5point oh no
never thought of that how would one fix it
a work in progress
Old Jun 16, 2010 | 10:25 PM
5point oh no
its aftermarket and old does need to be replaced anyway
a work in progress
Old Jun 16, 2010 | 10:27 PM
5point oh no
you mean a vaccum gauge on the return line
O.P.
a work in progress
