rotor problem?
Old Jun 6, 2010 | 07:40 PM
Ricksta's Avatar
I FUCK LIKE A PORNSTAR
Default rotor problem?
this girl im dating has an 03 or 04 ford focus. when it turns to the left there is a squeeling noise, but it doesnt squeel in reverse while turning in the same direction. could this be as easy of a fix as getting the rotors resurfaced?
sig pic removed
Originally Posted by pnkpnthr2133
that shit looks jagged, she's gotta open her mouth at some point so ricky can stick his dick in it...i don't want him to get hurt...
Old Jun 8, 2010 | 01:52 AM
OldMan's Avatar
Donut Killer
Dumb question, but have you checked the brake pads? Some brake pads have a 'squealer' plate attached. You might just be hearing that.
Also, IMO I would not cut/resurface the rotors. When you do, it cuts a thin spot causing the rotor to warp again. Just replace the rotors, as they are not usually that much more.
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
Old Jun 8, 2010 | 02:04 AM
GNs-r-slow's Avatar
Bondsman
+1 on advice of OldMan...most newer cars are out of spec, by brake wear. (meant to be replaced)
Old Jun 9, 2010 | 09:33 AM
Tony@1320Motorsports's Avatar
Yeah agreed ^^^^
You really dont want to re-surface the Rotors with any fords that are... i would say 10 yrs old or newer. You can buy new rotors for not too much more and only have to replace them once. Instead of going through this head ache again when those rotors start to warp cause they are so thin. That way you can know your girl is safe.
But... it might not be anything to do with the brakes at all you said the squeak comes from the left side on the front of the car and only when you turn forward in that direction not in reverse.
It could be your CV joint or a few things in the front suspension.
The key is when you turn are you going slow like 5mph or faster 20mph+? If it does squeak at all speeds does the squeak get louder or higher pitched the faster you go? Also when you turn and it makes that noise is your foot on the brake at all even lightly?
I know that seems like alot but you post those details and that will narrow it down to a few thinggs instead of all 50 it could be.
