AFR 185 VS trick flow twisted wedge
Old May 26, 2010 | 06:50 PM
st pete chad's Avatar
Originally Posted by GNs-r-slow
I'm with Dawg....dont think you'll loose or gain, making any changes
yea thats what i figured but i was just asking.i wonder if the flows numbers are correct on the 2 heads cause the AFR out flows the TFS by a good amount.hell the 185 are right there with the edelbrock victor jr
[IMG][/IMG]
357w s475 turbo Hughes powerglide
Old May 26, 2010 | 07:02 PM
GNs-r-slow's Avatar
Bondsman
Dont get hung up on flow numbers with a small frame turbo! You dont want the biggest runner head out there. Smaller runners provide velocity which ='s spool
Old May 26, 2010 | 07:55 PM
cochese's Avatar
Chucking up the Dueces
are those injectors big enough
Induction Performance.com
PTC torque converter
Aerospace Components
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
Old May 26, 2010 | 08:12 PM
BigDawg's Avatar
has his prioritys ef'd up
They should work just fine, if your using a standalone, check your duty cycle once you get going, dont be surprised if your running a 90% duty cycle at WOT. Hell, you might actually be maxing them out. Might want to look into some flow matched 72lbers.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old May 26, 2010 | 08:28 PM
a buddy has 60 and making over 800@ wheels so the 60 will do fine
[IMG][/IMG]
Old May 26, 2010 | 08:35 PM
BigDawg's Avatar
Whats his duty cycle? As long as the injectors dont starve the cylinders causing you to throw the pistons through the block being so lean, then all is well.
Ryan
Old May 26, 2010 | 08:38 PM
  #17 (permalink)
i dont have any clue i just know he has 60 and made 800+ but around town he is only running like 10lbs boost and making some where in the high 600 i think like 685
[IMG][/IMG]
Old May 26, 2010 | 09:28 PM
  #18 (permalink)
Iraq&Roll's Avatar
So this friend has only boost with 60 lb injectors making 800+ rwhp?
No extra alcohol or nitrous?
Is your friend Cobra390?
General Stonewall Jackson has been quoted saying that when the time of war comes,
“My advice is to draw the sword and throw away the scabbard".
Old May 26, 2010 | 09:35 PM
  #19 (permalink)
no not cobra 390 dont know who that is.no nitrous running race gas 80mm turbonetics turbo
[IMG][/IMG]
Old May 26, 2010 | 09:43 PM
  #20 (permalink)
Iraq&Roll's Avatar
Don't know how he makes 800+ with only 60's
any way
Where did you hear that the AFR's crack? Can you provide a link?
Coin toss on the heads. I think that the TFS heads have the most potential. Pick whatever head has the thickest decks and the best valve train.
