Guide plate help
Old May 23, 2010 | 08:38 AM
88califox5.0's Avatar
Default Guide plate help
Do windsor sr heads require spacific guide plates? I bought a set of guide plates but the rockers don't sit right on the valve stem which leaves me to believe that they require a spacific app. If so what.
Old May 23, 2010 | 01:01 PM
GNs-r-slow's Avatar
Bondsman
Please re-read what you posted, hopefully your not serious.
guide plates have nothing to do with rockers. Pushrod checker is your friend
Old May 23, 2010 | 03:10 PM
Well I did u the push rod tester not sure what that has to do with the rocker setting to the right or left of the valve stem!!!! But. Thanks for try'n.
Old May 23, 2010 | 03:36 PM
Zman's Avatar
I gota Cheby
forgot what brand but they do make adjustable guide plates I know on my SBC Darts they had to have them. It looks like they are split in the middle and you can slide them either way.
Only 1/4 mile track I know is Gandy Bridge
Old May 23, 2010 | 08:35 PM
GNs-r-slow's Avatar
Bondsman
Clarification is great! Maybe there still bent
Old May 23, 2010 | 08:40 PM
GNs-r-slow's Avatar
Bondsman
Old May 24, 2010 | 03:47 PM
I guess they could be, being brand new from comp cams!!!
Old May 24, 2010 | 03:48 PM
Thanks I found those!!!
Old May 24, 2010 | 04:32 PM
Zman's Avatar
I gota Cheby
also check the push rod holes inside the head to make sure there is enough clearance and some heads are off due to core shift
Old May 25, 2010 | 12:33 PM
K thanks. I will check on that.
