problem with 92 f150
Old Apr 29, 2010 | 03:37 PM
ruler's Avatar
97 gt
Default problem with 92 f150
my neighbor just did a lot of work to his truck and he is having some problems the shop cant seem to figure out. When sitting at a light the truck idles up and down (fluttering a little). The tachometer doesnt read below 2300 rpms but reads fine over that. He replaced the cluster in the dash and still has the problem. He said it feels like it is missing when sitting but runs fine under load. Any ideas guys?
Old Apr 29, 2010 | 04:25 PM
GNs-r-slow's Avatar
Bondsman
Maybe find out what work has been done to narrow down the problem
Old Apr 29, 2010 | 04:36 PM
ruler's Avatar
97 gt
new heads. new bottom end 1 year ago good compression after new heads installed.
Old Apr 29, 2010 | 05:09 PM
BigDawg's Avatar
has his prioritys ef'd up
id look for a vacuum leak somewhere, first. Hooked it up to a scanner? Has he checked the TPS voltage?
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old Apr 30, 2010 | 02:28 PM
ruler's Avatar
97 gt
I am thinking computer problem. He is on his second one and things dont add up on his story. Will a bronco 5.0 computer for the same year work on a 2wd truck?
Old Apr 30, 2010 | 07:27 PM
GNs-r-slow's Avatar
Bondsman
Being they done a lot of work, be sure all the ground straps are back in place
Old Apr 30, 2010 | 09:20 PM
Hurstmeister's Avatar
Bad MAP sensor can cause the idleing issue,.. as can vacuum leaks. But the tach not reading below 2300 RPM would lead me to seek out a bad ground on the coil or possibly the module on the distributor going bad.
4x2 and 4x4 should use the same computer. Both are air density motors. The only difference in computers for the trucks that I can think of would be 351 vs 302. But either should run the truck fine. If the computer went bad it shouldnt be running at all. The ECM relay needs to trigger fuel pump relay. If bad,.. the fuel pump wont come on.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old May 1, 2010 | 02:29 AM
ruler's Avatar
97 gt
thanks hurst gonna try your way before the new computer.
Old May 1, 2010 | 05:12 AM
Zman's Avatar
I gota Cheby
also check the IAC (idle air control)
Only 1/4 mile track I know is Gandy Bridge
