C4 to T5 swap on carbed 306!!! need help with neutral safety switch
I just did the c4to t5 swap, all went rather smooth except now when I turn the key it just turns, I thought maybe the lock cylinder for key broke so I took a trip to advance and replaced it, put new one in still same problem, Raymond (riverviewnative) told me its the Neutral safety switch, but on the last 5 speed swap i did the nss harness was under car left of tranny, this car there is not one there, Ray said its a black harness by kick panel, with 8 wires. I ran the test light and got nothing!!! And also do i have to run a wire from the Ignition wire to the selonoid? Does anyone know where the Neutral Safety Switch harness is by the kick panel. Pics would help also. Call Text Tyler 352-556-8283
when i say just turns, turns and does nothing, engine doesnt turn over
little more specific on the wire locations,
there wasnt a harness there under the car, raymond said there is one also by driver side kick panel. I just need to know which harness it is and the colors before i jump them.
Does it still have the plug by the pedal?? You should be able to see it if you shine a light under the dash by the clutch pedal. If the plug is still there you can stick a fuse in the plug and it will jump it.
Every time I cross one thing off of my TO DO list,I add two more!!!
ITS kinda hard to explain but heres a diff way .take the steering column cover off find ign switch turn key all the way. use a test light find the wire that lights up and run that wire to starter solenoid, done....
