Anyone run a high volume oil pump?
Old Jan 20, 2010 | 08:21 AM
351coupe's Avatar
refinish artist
Default Anyone run a high volume oil pump?
What's your oil pressure like?At idle,at cruising,and at wot.Thanks
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
Old Jan 20, 2010 | 08:56 AM
GNs-r-slow's Avatar
Bondsman
In the past Ive run them, fresh motor run 45 or so hot and 60-65 off idle
Old Jan 20, 2010 | 05:10 PM
Stoopid Wendy's Avatar
see dick run
Just don't run a high pressure pump. I twisted a good shaft and wiped out a dist gear in a very short time.
john
handle every stressful situation like a dog: if you can't eat it or play with it, just pee on it and walk away.
Old Jan 20, 2010 | 05:49 PM
franktf's Avatar
I use a standard pump in 302's and high volume in 351W's.....
Old Jan 20, 2010 | 06:58 PM
harold harper's Avatar
h9
Thats what i did.meiling standard in my 302 and meiling high volume in 351w.302 pump shaft is small compared to 351w.if really don"t need the more flow stick with the standard,it robs alittle power.make sure to use arp oil pumpshaft.
Old Jan 20, 2010 | 07:52 PM
351coupe's Avatar
refinish artist
Thanks for the advice guys,but I already put it in when I rebuilt the motor.Got a new one in a trade for some stuff.I guess I'll change it when I put the tubular front end in.Until then,on a high miledge motor is it normal for the oil pressure to drop below 30pounds hot?It stays at 40 then slowly drops off to 28-30 while sitting in traffic.I have about 50-55 crusing,and about 60-70 in the throttle.
Old Jan 21, 2010 | 02:06 AM
franktf's Avatar
Nothing wrong with that at all.....
Old Jan 21, 2010 | 02:49 AM
h9
my 302 with the standard pump when hot 205.it runs 25-30lbs at idle.
Old Jan 21, 2010 | 06:46 AM
351coupe's Avatar
refinish artist
Alright,it just worried me a little bit,thanks guys.
Old Jan 21, 2010 | 01:56 PM
GNs-r-slow's Avatar
Bondsman
pressures will depend on the grade of oil as well
