timing problem msd 6AL
Old Jan 19, 2010 | 09:34 AM
GNs-r-slow's Avatar
Bondsman
Should run better now
Old Jan 19, 2010 | 04:16 PM
rbarse27's Avatar
it is running little bit better. thanks for the help and the schooling. Anytime you need a hand let me know. I need to adjust the rockers.
Old Jan 20, 2010 | 04:23 AM
GNs-r-slow's Avatar
Bondsman
That puller fuel pump and 600 carb has to go. Start with a decent pump in the back (pusher) and go from there. It is running lean....that is causing the popping when its running out of fuel
Old Jan 20, 2010 | 05:53 AM
DrDirt's Avatar
Team Geritol Racing
So what it wuz?
YO! Barry! You LOST!
Old Jan 20, 2010 | 05:58 AM
GNs-r-slow's Avatar
Bondsman
Originally Posted by DrDirt
So what it wuz?
It has a tiny Mr Gsket pump mounted up front using it to pull fuel from the back and a 600 vac sec. I dont think the pump is keeping up is the biggest problem and it is lean poppin. The distributor was a tooth advanced.
Old Jan 20, 2010 | 06:04 AM
DrDirt's Avatar
Team Geritol Racing
Ohhhhhh. The carb cure-all didn't ?
I've got a Holley Blue that I don't know what to do with. And a shiny regulator. (You may have seen it somewhere in your travels) Sheeut, I've even got a braided stainless double jointed, AN fitted carbolator fuel gizmo that I've been thinking of making a Navajo Flute out of for lack of any other thing to do with it.
Old Jan 20, 2010 | 06:08 AM
  #17 (permalink)
GNs-r-slow's Avatar
Bondsman
Ive got a new pump and regulator I offered him also. Thats what it needs. Plugs were lean....bad
Old Jan 20, 2010 | 06:13 AM
  #18 (permalink)
DrDirt's Avatar
Team Geritol Racing
Dayum! It couldn't keep up at 3 grand? I didn't know Mr. Gasket made pumps for a Briggs & Stratton.
Old Jan 20, 2010 | 06:46 AM
  #19 (permalink)
GNs-r-slow's Avatar
Bondsman
Maybe it would fair better in the back. But its mounted by the headlight pulling from the tank
Old Jan 20, 2010 | 07:09 AM
  #20 (permalink)
rbarse27's Avatar
Well I agree with all the commits. I haven't had the ride long and I knew I needed to replace the pump. I got new plugs in it and a set of MSD wires also. Just need the money to buy your pump and line setup. I just broke the $1,000 make on it yesterday, so I'm still way ahead of the game.
