Good alignment shop?
Old Jan 15, 2010 | 07:17 AM
Jaden's Avatar
Default Good alignment shop?
Hey guys,
I'm new to the area and I'm looking for a good alignment shop in South Tampa. I'm upgrading to Koni shocks and struts and Steeda sport springs this weekend. Thanks.
2007 Mustang GT - mostly stock
Old Jan 15, 2010 | 10:40 AM
harold harper's Avatar
h9
shauns shop. his name here is na306stang i believe.he has a shop close by to you with good labor rate.he is doing my car next weekend.shop all american street cars.
Old Jan 15, 2010 | 08:54 PM
BigDawg's Avatar
has his prioritys ef'd up
If your in South Tampa, then look no further than Southern Tire on MacDill Avenue. Talk to a guy named Dwayne. He will take care of you.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old Jan 15, 2010 | 10:13 PM
EFI-Unlimited's Avatar
S&R Performance in Tampa has a John Bean alignment rack that gets calibrated every 6 months. They are familer with performance alignments and corner balancing. If you are just looking for a run of the mill alignment, you can go anywhere, but if you are looking for a specialist that takes your alignment seriously, these are your guys.
S&R Performance
9509 N. Trask St.
813-961-0609
Brian
EFI-Unlimited
Old Jan 16, 2010 | 09:34 PM
Stealth Mode's Avatar
Still CREEPIN
+1 For All American Street Car Performance.
TurboRAM Member #5
24psi & Stable
GET SOME
Old Jan 17, 2010 | 02:03 PM
Jaden's Avatar
Thanks for the info guys. I ended up getting it done at Tire Kingdom on South Dale Mabry. It was a pretty easy job. The camber and toe were slightly off. Thanks again.
Old Jan 18, 2010 | 07:33 AM
Na306StAnG's Avatar
Flowmaster nut swinger
Thanks guys
https://www.tamparacing.com/forums/a...an-do-all.html
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Jan 18, 2010 | 03:41 PM
Jaden's Avatar
Wish I had gone to All-American. The guy never really got the camber to where I wanted it. I wanted -1.2 on both sides, but ended up with -1.4. He kept trying to align it in the air and of course when he let it down the camber was off. Did this several times and then I just finally said leave where it is, which ironically is where the camber was when I first brought it.
Old Jan 18, 2010 | 04:11 PM
MiDiablo's Avatar
Definitely take it to All American. Shaun and his crew aligned my car, readjusted the suspension to get it to align correctly, and also installed my caster/camber plates and the car is dead on.
