valve cover clearence issues!!!!!!!
Old Jan 13, 2010 | 09:00 AM
purple87lx's Avatar
just a single cam hatch
Default valve cover clearence issues!!!!!!!
ok so i have a set of 1.72 roller rockers on a 302 im building and im trying to find a set of valve covers that will clear the rockers and the stock EFI intake. i have a set that clears the rockers but they wont clear the intake. they would if i had a 1/2 inch spacer. but the only size spacers i can find are 3/8 or 1 inch. so any help would be great. lol and the 302 has a ford racing F303 cam in it.
Old Jan 13, 2010 | 09:25 AM
Stealth Mode's Avatar
Still CREEPIN
I think the stock H.O valve covers clear the 1.7s. If not, I know for a fact the Ford Racing valve covers do and should be able to fit under the intake.
Just curiousity here, but why build an engine with an F-cam and have a stock intake? You're not using the stock E7's too right?
TurboRAM Member #5
24psi & Stable
GET SOME
Old Jan 13, 2010 | 10:34 AM
SpankReasY's Avatar
Bih make and weld your own valve cover!
Old Jan 13, 2010 | 01:13 PM
slow poke's Avatar
ford motorsports and a company called jomar make a .5" spacer.
just visiting this screwwey planet.
woohoo, 9.84 @ 137.7 mph on a 9" slick !!!!
Originally Posted by Gooser
just cause you have a cowl hood on your Honda doesn't mean you can hang out here.
Old Jan 13, 2010 | 01:20 PM
SVT1996Cobra's Avatar
What?
stock valve covers can be cleareanced to worked with 1.72 rockers and a stock cam, but i don't know about an f-cam
Old Jan 13, 2010 | 03:00 PM
Tiffiny's Avatar
I can fix your bullshit
all you have to do is remove baffle in stock v/cover
Old Jan 13, 2010 | 06:00 PM
purple87lx's Avatar
its just a stock motor. im just building it with parts i have laying around. and yes it has stock E7's. but i ported and polished them and took the smog humps out of them, put crane cams vale springs in them, and gasket matched the intake. its replacing a old motor with alot of miles and has severe blow by.
Old Jan 13, 2010 | 08:48 PM
chevy eater's Avatar
like john said,remove the stock baffle and they clear the stock covers
Old Jan 14, 2010 | 02:26 PM
barry bledsoe's Avatar
The lost pony
3/8 spacer is almost 1/2 once you add the 2 gaskets. but I am all for removing the baffles its cheaper
