bad injector?
Old Dec 26, 2009 | 06:59 AM
SlowCivicEg93's Avatar
Default bad injector?
How common is it for a injector to become lazy or preform shitty? I know theres a test you can do to the injectors but im not exactly sure how its done... can anyone give me some insight? Thanks
Old Dec 26, 2009 | 08:13 AM
GNs-r-slow's Avatar
Bondsman
Noid light,. Not perfect but will shoow you the weak one(s). If they are not stock....I sent mine to GA to Cody Motorsports to be serviced and flowed.
Old Dec 26, 2009 | 01:45 PM
Tiffiny's Avatar
I can fix your bullshit
how will a noid light tell you an injector is weak....lol your thinkin injector pulser tester thingy
pinellas diesel flows injectors
even if the injector pulses it still may not spray right.
unless it sat for along time or you put shitty gas in it
its probably not the injector
Old Dec 26, 2009 | 03:33 PM
GNs-r-slow's Avatar
Bondsman
Does a noid light only show current to the injector?
Old Dec 26, 2009 | 10:03 PM
Tiffiny's Avatar
yes you plug it in the harness and it blinks.
Old Dec 26, 2009 | 10:19 PM
GNs-r-slow's Avatar
Bondsman
Is there one that plugs inline of the harness and then to the injector?
Old Dec 26, 2009 | 10:37 PM
Tiffiny's Avatar
not that i know of .i have one with a long probe that you put on the injector and it tell you that it is pulsing..
Old Dec 27, 2009 | 09:28 AM
Mars_302's Avatar
Race Photographer
yea some of the fancy noid light kits come with an inline harness
Old Dec 27, 2009 | 11:18 AM
Stoopid Wendy's Avatar
see dick run
We have a tool at work that, you power up the fuel pump (for a moment), then open the injector and watch the fuel pressure. The amount of drop will tell you how much is coming out. It's kinda mickey mouse but works.
john
handle every stressful situation like a dog: if you can't eat it or play with it, just pee on it and walk away.
Old Dec 27, 2009 | 12:05 PM
Tiffiny's Avatar
john
can you use this on the car or on the bench.just curious
