Need Help Getting Car Started - Pic Included of Issue
Old Nov 21, 2009 | 09:23 AM
Anarchy99's Avatar
Default Need Help Getting Car Started - Pic Included of Issue
So the car sat a couple days and I went to start, wouldnt fire just clicks battery is fully charged etc. Well I had my friend turn the key multiple times so I could look around and there are sparks coming off the two main bolt/screws going into the solonoid where the wires all bolted down on. They are just little sparks nothing crazy but the car is not turning over and I am wondering if this just randomly took a crap or if there is something that needs to be crossed/bypassed to start the car? Sorry rookie when it comes to this type of stuff, pic below.
Old Nov 21, 2009 | 10:10 AM
95coBraSVT's Avatar
banana republic
I see no pic. HOWEVER, if the starter solenoid has sparks coming off it, thats a bad sign. I would check your connections. If they're all good, and it is still sparking, then replace the solenoid. As a privy to the life of bad solenoids and a whole plethora of other issues that Chebbies don't have. Of course, our issues are easier to diagnose and fix. LOL
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Nov 21, 2009 | 10:19 AM
Anarchy99's Avatar
Tried a different format for the picture let me know if you can see it.
Old Nov 21, 2009 | 01:52 PM
DrDirt's Avatar
Team Geritol Racing
There should only be one wire on the right hand post. That would be the + wire to your starter. The rest of the wires should be on the same post as the Battery + cable. Off the top of my head, Id say those yellow wires are shorting out when you hit the key to start. Make sure they are not shorted out somewhere before you hook them to the + post though. Also, make sure the little metal box is not shorting out against sometning. It's the circuit breaker for your door locks.
YO! Barry! You LOST!
Old Nov 21, 2009 | 02:03 PM
95coBraSVT's Avatar
banana republic
Crap. I had no idea ou had extra wires coming off the solenoid. Those are instantly suspect IMO.
Old Nov 21, 2009 | 02:28 PM
Anarchy99's Avatar
Ok I will take the next steps to relocate the wires properly. Good eyes guys, I bought the car like this so I just have to clean it up
Old Nov 21, 2009 | 03:11 PM
DrDirt's Avatar
Team Geritol Racing
Just be careful not to let all the smoke out of the wires. If you do, they won't work anymore.
Old Nov 21, 2009 | 03:59 PM
Anarchy99's Avatar
Hahaha I will try.
Old Nov 30, 2009 | 03:49 PM
Anarchy99's Avatar
Ok update, removed the yellow wires. Those worked the electric fan. Still not firing, not sure if it is sparking need to have someone by the car while i turn the key. It is still just clicking. Would we all assume it is that solenoid that might just be bad?
Old Nov 30, 2009 | 05:32 PM
GNs-r-slow's Avatar
Bondsman
Did you have to ride down the road holding the key to start for the fan to work? Thats the only way they would of came on wired the way it was.
