Ford Ranger electrical question
2003 Ford Ranger, 3.0L non Flex
For some reason it's not starting. The engine isn't cranking, but the electronics are coming on. When you try to start it, instead of the normal clicking you would get if it was low voltage, it's an almost buzzing sound and the lights flicker. I want to say that I think it's the starter, but I'm not positive.
Any ideas as to what it could be?
I just went over to her house and hit the starter a few times and nothing. It actually was clicking a little, but the sound was coming from almost directly underneath the driver instead of from the engine compartment.
Take a battery out from another vehicle and put it in it. If it still doesnt start then buy another starter.
Problem solved.
My name is Hurst and I approve this message.
Hurst
Problem solved.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
When I have that problem its usually a loose battery cable attachment to the battery post. I won't admit it out loud, but I once pulled my motor out of the car because I thought I had cooked a starter when really all I needed to do was tighten that one bolt
Take a battery cable and jump across + battery to the starter (in neutral of course) see if the starter turns over. Maybe a pain in the ass cause I think those solenoids are on the starter themselves.
.Take a battery cable and jump across + battery to the starter (in neutral of course) see if the starter turns over. Maybe a pain in the ass cause I think those solenoids are on the starter themselves.
"They must really feed each other to the lions down there........"
