2v to 4v swap
Old Oct 23, 2009 | 01:32 PM
ruler's Avatar
97 gt
Default 2v to 4v swap
I know this has been done a thousand times but I am looking for a cost effective way to do this. Hurst if you could link up or post a parts list. I am thinking about using b heads and would like to know what 4v intakes work with what heads and all the parts I am gonna need to make this happen.
Old Oct 23, 2009 | 02:10 PM
bvh's Avatar
bvh
4v front cover , heads and a matching year intake, throttle body, coil pack mounts, spark plug wires, coolant cross over. im sure there are little thing hear and ther u will need. but now cost effective way, i know "I" can do this cheap, get a mark viii front cover for about 50.00... heads mark viii $50-$150 .. B heads are the only heads u can get cheap. the intake by far will be the most expensive thing. 96-98 cobra intakes run about $450-$600.
Old Oct 23, 2009 | 02:17 PM
ruler's Avatar
97 gt
what is the difference between b heads and mark 8's
Old Oct 23, 2009 | 03:05 PM
saleencoupe93's Avatar
F.T.W. THE ONLY WAY I FLY
I Have 96 Cobra A Heads Complete With Cams For 199
Old Oct 23, 2009 | 04:46 PM
bvh's Avatar
bvh
you mean b heads... mark viii heads are b heads, currents heads 99+ are c heads . c heads have a bigger pice tag and unless u want to do a 03 cobra setup they are not worth the money. but mark viii heads and cobra heads are the same as far as casting goes, but cams are not the same and some year markviii have weaker valve springs... as far as intakes go cobra intakes is almost ur only option unless u want a spend 1200 and lose all of ur low-end...
Old Oct 23, 2009 | 05:50 PM
ruler's Avatar
97 gt
keep the useful info coming. What about ecu?
Old Oct 23, 2009 | 06:57 PM
Hurstmeister's Avatar
The easiest way to do a 4v will be to buy complete engine and swap it over. I dont think it would be cost effective to piece out the swap and use your short block.
Lets look at it realistically.
1: Used B heads, unknown condition - $200 - $400 (Hopefully they are Cobra heads with Cobra cams,.. else expect to be down 20 RWHP with Lincoln cams vs Cobra cams) Add $100 - $200 if they dont come with Cobra cams and you need to buy the Cobra intake cam. (4v all use the same exhaust cam profile)
2: Felpro MLS head gaskets - $50 x2 = $100
3: 4v B head valve covers - $100
4: Felpro valve cover gasket kit - $85
5: Cobra intake - $300 - $600 (Add $100 - $200 if it doesnt come with a throttle body)
6: Felpro intake and IMRC gasket kit - $45
7: 4V front timing cover - $30 - $75
6: Felpro timing cover gasket kit - $30
7: Front timing cover crank seal (Not included in timing cover kit) $12
8: Timing chain tensioners - $40 x2 = $80
9: Timing chains primary - $35 x2 = $70
10: Timing chains secondary - $29 x2 = $60
11: Cobra fuel rail and 24lb injectors - $75 - $100
12: 4V Thermostat, thermostat housing, upper and lower coolant hoses - $100
13: Belt tensioner assembly - $50
14: Serpentine belt $20
15: Stock Cobra exhaust manifolds $20 - $50
OR
16: BBK, Mac, Hooker or similar Headers - $300 - $400 (Used) $550 - $900 (New)
17: Exhaust manifold gaskets - $15
18: BBK, UPR or similar CAI with filter - $100 (Used) $250 - $300 (New)
19: Cobra throttle and cruise control cables (GT cables will be too short) - $100
Grand total - 'Roughly' $1800 and thats not including exhaust headers or manifolds. And this is assuming you will be doing all the labor.
Alternative# 1
Find a 94 - 98 Mark8 engine or whole carr.
Something like this would have been ideal,..
Link: CARS YOU FIX: 1993 Lincoln Mark Viii Link
Then part out the rest of the car.
Most Mark8 engines in running condition can be had for $400 - $600.
96 98 Cobra intake cams - $200.
96 - 98 Cobra intake with TB, $500
Used CAI - $100
Reuse the GT wiring harness and computer.
Total = $1350
Alternative #2
Find used Cobra engine, Aviator engine, Navigator engine, Mach1 engine, - I've seen them as low as $1000 and as much as $2500 complete with low miles. You just gotta shop around.
As far as installation,.. everything is pretty much a bolt in. No modifications needed. Even if you use a later Aviator or Navigator engine that originally used COPs,.. your 4.6 ignition modules will bolt to the front of those heads just like they did on your 4.6 and are perfectly fine for a performance application on those engines. Stock GT engine harness,.. just have to extend a couple wires for the injectors to reach around the manifold. If you use a 99+ motor will need a 99+ manifold,.. Pre 99 will be relegated to a 96 - 98 Cobra manifold as your only real performance option. The stock GT ECU is fine. May run a little rich untuned. The thing is to not mix and match wiring harnesses. If you plan to use a 2001 engine with 2001 engine harness,.. you will need the 2001 indash/ECU harness as well. The pin outs at the firewall are different for different models. Even within the same year,.. say 96 GT and 96 Cobra,.. the wiring harness' are not compatable with each other. The pin outs at the block are different. I went through this with mine trying to use a 96 Cobra engine harness with a internal wiring harness. I couldnt even start the car with the key,.. the pin out to engage the starter was different. Brian of EFI-Unlimited spent 4 hours re-pinning it and it still wasnt 100%. Wouldnt go to closed loop because of an O2 read problem. Replacing the Cobra harness with the GT harness fixed it.
Also,.. if you use a pre 99 engine you will need to perform an IMRC delete or manually lock the plates open else the engine will choke on it self at over 3500 RPM because the plates are stuck closed.
I dont know all of the details with the 99+ engines. Kelly (Modular Performance) or both Brians (BVH or EFI-Unlimited) know alot more about those then I do. I know enough to make it work in a 96 - 98 car. I know more about the 96 - 98 engines because thats what I have had hands on experience with. But I know enough that if you get a later model engine that I would feel comfortable enough to help you install it correctly and enough that I know it will start and at at least run well enough that you can drive it to a tuner with out destroying it.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old Oct 24, 2009 | 02:21 PM
bvh's Avatar
bvh
jim theres alot on that list u dont need such as the timing components, throttle cable,.. that is very realistic list, but alot of stuff such as seals are reusable. some times i forget how cheap i get stuff, and how much i have laying around. 2 weeks ago i gave a whole 4v swap way for free minus the intake.
Old Oct 24, 2009 | 03:31 PM
ruler's Avatar
97 gt
Im looking for a deal like that but I want a teskid with it too.
Old Oct 24, 2009 | 03:43 PM
bvh's Avatar
bvh
i got a teksid fs
