bent axle?
Old Oct 10, 2009 | 02:04 PM
stealth gt92's Avatar
Default bent axle?
so today my buddy told me it looked like my left wheel was slightly wobbling so i drove behind to make sure and see and yesss... there is. so my question is should i buy new axles? and is this the actual problem?
Old Oct 10, 2009 | 02:20 PM
302GTS's Avatar
Resident TOB Killer
Check lugnuts for tightness? Buddy of mine has a 91 Dodge Ramcharger that kept shearing wheel studs, and wheel wobble caused it from only running 4 out of 5 studs.
Old Oct 10, 2009 | 03:40 PM
ill check.
Old Oct 10, 2009 | 06:11 PM
Hurstmeister's Avatar
This is the rear wheel wobbling I assume. Check to make sure the rim is not bent before you go through the trouble of replacing an axle. Odds are its the rim and not the axle. Get it on a balancing machine and have them spin the wheel. If its wobbling on the machine then there is your culprit. Or,.. swap the wheel with one from the front and then see if it wobbles on the front and if the one on the back doesnt. An easy way to tell if its the axle or not is to pull the axle out and roll it on a flat surface.
I bought a set of 17x8 96 - 98 GT wheels off Ebay,.. the guy lived in Cocoa beach,.. so I drove over to get them. The wheels looked like they were in great shape,.. no curb rash,.. looked perfect. For $175 I thought I got a great deal. Wasnt untitl I got new tires mounted on them that I discovered that 2 of the wheels were bent. I contacted the guy and asked for my money back. He said I bought them as is,.. I was pissed. So I drove to his house late at night and pitched a rim through his front living room bay window. I know he knew who did it,.. but he never contacted me nor did I ever have any police knocking on my door.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old Oct 10, 2009 | 07:36 PM
BigDawg's Avatar
has his prioritys ef'd up
Could be bad axle bearing. But I would take the wheel off and get it checked.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old Oct 10, 2009 | 07:49 PM
ruler's Avatar
97 gt
Hurst
Air mail?
Old Oct 11, 2009 | 08:21 AM
Swap the wheel to the other side of the car and see if
it stops wobbling.-Bob
Old Oct 11, 2009 | 09:25 AM
tightened the wheels up seems like one lug on each rear wheel had a couple turns left to tight its not doing it anymore from what my friend saw.
Old Oct 11, 2009 | 10:53 AM
302GTS's Avatar
Resident TOB Killer
Old Oct 11, 2009 | 04:59 PM
SVT1996Cobra's Avatar
What?
probably just an optical illusion due to dirt on the tire/wheel. One loose lug is not going to make the wheel wobble
