Tire size
Hey does anyone know how tall of a tire can go on the new body style mustangs. I want to put a 28x10.5 but am not sure if that is too tall. I know for a fact that 26x10.5 will fit because that was what I ran with slicks but there seemed to be some room there. This is for stock ride height.
Guest
Posts: n/a
Should fit but dont forget a 28 inch tire will take away some of your gear. So your e.t.s will not translate the same from your street tire to your slick. However the car will launch more consistantly with a 28 inch tire.
Just keep that in mind.
With a 28 tire u have to remove your quadshock(or flip it cant remember). Other than that u should be fine. However if its over 10.5(I think) u have to bend the lip on the inside of fenderwell. The difference is a 28 tire will have alot more tire growth on the high end. On paper it equates to about a 500rpm difference. -Mark
98' cobra
98' cobra
Originally posted by "Someone"
Originally posted by Fordman
Just remember the gear ratio loss and different rpms when you go through the traps.
