backspacing on welds question
Old Sep 10, 2009 | 01:31 PM
ruler's Avatar
97 gt
Default backspacing on welds question
Ok, so I have heard 5.5 backspacing on a 8 inch wheel is ideal. What is the ideal backspacing for a sn95 front wheel if I want to use 15x8.
Old Sep 10, 2009 | 01:54 PM
CBRTRX's Avatar
car with tiny wheels
Why a 15x8 front? if you dont want a skinny on the front you can do a 15x6 with a 225 tire, it still will handle fine. But to answer your question if i had a 15x8 rear with a 5.5" BS then id do a 15x8 front on a 6" BS just so the fronts will sit in slightly from the rear to give it a better look and to also keep in mind that welds need small spacers to clear front calipers.
in memory of Kevin Gonzalez 6/21/86 - 9/13/06
Old Sep 10, 2009 | 03:40 PM
ruler's Avatar
97 gt
what backspacing would I need for a 15x6
Old Sep 10, 2009 | 06:17 PM
Hurstmeister's Avatar
SN95 and Fox use the same back spacing, SN95 has a little more play room in the rear,.. but for the most part are the same.
8" wheel = 5.5 BS
9" wheel = 5.9 BS
10" - 11" wheel = 6.5 BS
Doesnt matter if 15, 16, 17 or 18 inch wheels. BS is the same.
SN95 has a slightly longer rear axle and a little more fender which allows them to run an 10 - 11 inch wide wheel in the rear with little to no modification. On a fox usually the quads need to be removed and in some cases the tail pipes may need to be modified as well.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old Sep 10, 2009 | 07:17 PM
CBRTRX's Avatar
Well if your gonna use a 15x6 up front then a 4" BS would give you the best look to match your 15x8 5.5" rear ones.
Old Sep 10, 2009 | 08:28 PM
ruler's Avatar
97 gt
thanks guys. Im looking for 2 prostar 15x6 with a 4bs then. Keep a look out.
