Please Help!
Old Sep 8, 2009 | 02:56 PM
DarkHorse's Avatar
Back again...
Default Please Help!
hey guys this is what my problem is, my AC works but it only comes out my defrosters, this is the best way i can explain it.
((Get Staggered))
Old Sep 8, 2009 | 03:12 PM
302GTS's Avatar
Resident TOB Killer
The a/c vac line is cracked or broken. Look at the HVAC tree on the driver side fender near the firewall. It has lines running to, I believe, brake booster, interior HVAC controls, and I think p/s pump?? The a/c one is the middle one I believe. You can buy some hard line for like 10 bucks for 6' I believe from Advance. I just used heatshrink and fused together some lines to make it work.
Old Sep 8, 2009 | 03:49 PM
BigDawg's Avatar
has his prioritys ef'd up
Or if you have been doing some under dash work, there is a vacuum check valve, or actually a couple of them in and around the heater core box. You might have accidentaly foced it off or it might have come off.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old Sep 8, 2009 | 04:16 PM
DarkHorse's Avatar
Back again...
Ok thanks guys for the info.
((Get Staggered))
Old Sep 10, 2009 | 07:53 PM
Zman's Avatar
I gota Cheby
or the big plastic ball under the passenger fender inside the wheel well.
Only 1/4 mile track I know is Gandy Bridge
Old Sep 11, 2009 | 02:22 AM
BigDawg's Avatar
I thought the big plastic ball was for the cruise control assembly?
Ryan
Old Sep 11, 2009 | 05:34 PM
Zman's Avatar
I gota Cheby
The one I'm talking about is for the a/c vents. It holds vacuum for the selector switch. I had to replace it on my 88 GT years ago. Took forever to find the problem back then.
Old Sep 12, 2009 | 08:15 AM
95coBraSVT's Avatar
banana republic
It's a vacume line on line for the AC. Most likely on the passenger side firewall right before the line goes into the firewall. But I don't know anything.
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Sep 12, 2009 | 09:00 AM
Joker Instituted's Avatar
wanna be ford guy.
i never use a/c so yeah sorry just listen to what they ^ said.
its ok, the more parts that fall of the lighter i get.
Old Sep 12, 2009 | 04:59 PM
DrDirt's Avatar
Team Geritol Racing
Another thing to check is the little one-way valve that's inline somewhere close to the vac tree. If that goes bad it's just like having a vac leak.
YO! Barry! You LOST!
