Ignition problem (tumbler related)
Old Aug 8, 2009 | 08:24 AM
BIGBOI's Avatar
Default Ignition problem (tumbler related)
Okay. Back about a month ago I posted I had problem with my car "bucking while driving"
Well fast forward a few weeks the problem is worse now. The car won't stay on without holding the key in the "on" position
Well this sorts my problem out I believe
If I change the ignition switch assembly will this fix the problem?
Replace a 1979-1993 Ignition Switch Assembly
Old Aug 8, 2009 | 01:12 PM
fuelie327's Avatar
only one way to find out . You pretty much have your answer,lol
Old Aug 8, 2009 | 01:19 PM
GNs-r-slow's Avatar
Bondsman
They do go bad
Old Aug 8, 2009 | 01:59 PM
barry bledsoe's Avatar
The lost pony
thats probably it or adjust the old one but they are cheap just replace it.
Old Aug 9, 2009 | 01:02 PM
BIGBOI's Avatar
Well it's fixed! 10 dollar part and fixed in about an hour.
Old Aug 11, 2009 | 08:14 PM
Superwes98's Avatar
Well before u rip your hole ignition out u can u can try to connect i push button starter and if it still does it u know its not your actual switch and it will save u some time and head aches
Old Aug 12, 2009 | 05:13 AM
The lost pony
uh I think its already fixed. and its just a little switch at the bottom of the colum. no ripping required
Old Aug 16, 2009 | 08:50 AM
BIGBOI's Avatar
It was the box that was worn out. The "slides".. It was funny I can feel a much better difference in the key action when I turn the car off and on.
