What is the answer?
Old Aug 1, 2009 | 10:18 AM
Stealth Mode's Avatar
Still CREEPIN
Originally Posted by GNs-r-slow
Advanced sells them in pairs
I got 6 pairs of these things... They work great, atleast in the cars i installed them on they did.
PM me if you're interested in em Tim.
TurboRAM Member #5
24psi & Stable
GET SOME
Old Aug 1, 2009 | 10:26 AM
500HPLX's Avatar
I used the Taylor Wire protectors. They are made out of some stuff that will not burn, I know I put FIRE to them to test them.
I had the same problem with the stainless Ford headers on my P heads. It kept burning up the one by the oil dipstick tube (#7 I think)
I am using the Ford Racing wires.
I put these on there about 3 years ago and havent had a problem since.
In the Projects forum, under my car in "Progress of a never ending project". on page 2 there is a side shot of my engine with them on it.
Good luck.
Old Aug 1, 2009 | 10:28 AM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
switch to some 45* boots? i had to run those with my p heads and bbk headers, otherwise id cook plug boots in a run.
SUCH IS THE RULE OF HONOUR.
Old Aug 1, 2009 | 12:22 PM
91Notch's Avatar
Is workin on his car
The Taylor 45 degree boots worked for me when I had this problem when I had BBK egual length shory's.
Also dont be affraid to get some header rap and put it around the tubes that are giving you problems....then even on top of that use the boot protector.
Might be over kill but with those three things in place it should NEVER burn again!
Old Aug 1, 2009 | 04:35 PM
95coBraSVT's Avatar
banana republic
Tommy, The problem is not the individual heat of that tube. It is the design of the tube it's self. You see, the wire boot actually touches the header tube. So, no matter what I do, it will burn. I would have to have it running so rich that it was pure fuel going down the tube to make it cool enough not to burn the boot....and that may not be enough to solve the problem.
Dave and everyone else who suggested the boot sleeves. I already have those on #3 and #4 boots. This solved the number 4 boot problem, but #3 is still an issue.
Dave, I have put header wrap on that tube, and I have 90* angle boot on it as well as the boot sleeve. It still burned. I only have one layer of the header wrap on there though, maybe I need more?
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Aug 1, 2009 | 04:57 PM
Zman's Avatar
I gota Cheby
would a shorter plug help, it did in my situation
Only 1/4 mile track I know is Gandy Bridge
Old Aug 1, 2009 | 05:05 PM
  #17 (permalink)
95coBraSVT's Avatar
banana republic
IDK honestly. Possibly? I'll try to find some. I think I'm using autolite 45's on these heads....but I'll have to pull one to make sure.
Old Aug 1, 2009 | 05:11 PM
  #18 (permalink)
Zman's Avatar
I gota Cheby
they were accel's Gear head should have them.
Old Aug 1, 2009 | 05:13 PM
  #19 (permalink)
95coBraSVT's Avatar
banana republic
They open tomorrow?
Old Aug 1, 2009 | 05:46 PM
  #20 (permalink)
throw the shitty headers on ebay and buy some that fit.
