Timing cover seal stuck
Old Jul 15, 2009 | 01:03 PM
Pony 5.0's Avatar
Default Timing cover seal stuck
My timing cover seal is stuck but good. I'm prying like a mother all the way around it but it is not budging. I'm afraid the cover will crack before the seal comes off. Does anyone know of any "trick" in removing the seal? Thanks.
1990 Mustang GT, Holley Systemax, GT40X, B-cam, 24lbs injectors, Pro-M 80mm, 70mm PP TB, BBK LT w/X-pipe, Magnaflow catbacks, Baer, Eibach, Tokico, Walbro 255lph, UPR subs/uppers/lowers, 31 spline Mosers
Old Jul 15, 2009 | 03:57 PM
shinysideup's Avatar
TR Balla Donor Supreme
Use a punch to knock it out from the front.
Old Jul 15, 2009 | 05:09 PM
fuelie327's Avatar
are you sure you got all the bolts out ? Even the ones at the top and the oil pan
Old Jul 15, 2009 | 05:10 PM
500HPLX's Avatar
Is the water pump off?
Old Jul 17, 2009 | 03:03 PM
HELMUT RONER's Avatar
USAFR Veteran
They are supposed to be hard. I take it you haven't removed the cover from the engine and you're trying to replace the seal while the cover is still in place. It's been 2 days since the post. Have you gotten it off already? ANSWER ME! ANSWER ME NOW BEFORE MY DORITOS GET SOGGY FROM THE CHEESE DIP!
Helmut
Old Jul 17, 2009 | 05:05 PM
fuelie327's Avatar
Now I see I didn't read it all the way.The seal? I was thinking just the cover
Old Jul 17, 2009 | 05:40 PM
500HPLX's Avatar
Same here, Duh!
Old Jul 18, 2009 | 02:20 AM
fuelie327's Avatar
I've always called it the crank seal
Old Jul 30, 2009 | 09:58 AM
Pony 5.0's Avatar
Timing cover was out of the car. I used a center punch and worked my way around the seal from the rear. I did not use a lubricant when I installed the seal six years ago and the seal case galled onto the the timing cover. Note to self: install using a touch of lubricant. Thanks for all of your help.
Old Jul 30, 2009 | 10:06 AM
500HPLX's Avatar
Damn, talk about "dry running it"
Even a little spit on it would be appreciated!
