88gt fuel pump wont shut off
Old Jun 9, 2009 | 12:09 PM
barry bledsoe's Avatar
The lost pony
Default 88gt fuel pump wont shut off
88 gt fuel pump wont shut off when you turn the key off. if you disconnect the battery it shuts off. re connect the batteryits off until you turn the key on again.
Old Jun 9, 2009 | 12:17 PM
500HPLX's Avatar
My 88 LX has a fuel pump relay under the drivers seat. ChecK there and see if it is bad.
Old Jun 9, 2009 | 12:38 PM
The lost pony
how can i tell if its bad?cuz thats what i thought and the cosmetics of it look fine
Old Jun 9, 2009 | 12:56 PM
JohnnyPC1's Avatar
When you just turn the key on, engine off, do you hear the familiar spin up of the fuel pump? Or at this point does it keep running too? Fuel pump should shut off with key on but no pulses from the TFI...
Simple test for a sticky relay is to catch the thing running, when it should be shut off - then reach under there and tap tap tap the relay with a wrench or something solid enough to give it a good knock - if it mysteriously shuts off then that would = bad relay...the contacts got gooey or fried enough that it literally sticks in the closed state.
If it doesn't then ??? something electrical is keeping the relay on...TFI, computer, wiring etc...
Old Jun 9, 2009 | 01:16 PM
500HPLX's Avatar
You got a multimeter and a manual?
The lost pony
yup,its the relay,thanks man
Old Jun 9, 2009 | 01:57 PM
HELMUT RONER's Avatar
USAFR Veteran
It's 21 years old. Relays are famous for failure in these cars and so many owners fail to consider them an issue.
Helmut
Old Jun 9, 2009 | 02:15 PM
500HPLX's Avatar
Awesome!
Glad you found it.
Another one that is prone to crapping out is the AC cutout/
WOT relay. Mine was up by the air box on the fenderwell. One day on a long cruise, the AC quit. I found a crapload of melted pink wire. That is how I found it. Had to replace the relay and the pigtail for it.
Keep and eye on the harness. These things are starting to show their age!
