fuel pump problem
Old May 24, 2009 | 06:47 AM
Zman's Avatar
I gota Cheby
Default fuel pump problem
On my 93 5.0 yesterday my car again fluttered but this time the check engine light came on and I noticed that with the key in the on position the fuel pump would not shut off, I know that they cycle with the key on for about 15 secs and then turn off till you go to full start cranking. So maybe my problem is fuel related? Today it runs fine till who knows. the engine light is also off. Bad relay?
Only 1/4 mile track I know is Gandy Bridge
Old May 24, 2009 | 04:46 PM
Pshull727's Avatar
i would try replacing the relay and being that its been raining alot this kind of lil crap will happen
2008 Acura TL DD
1998 Beater Ranger DD
1994 Ford Mustang Project
Old May 25, 2009 | 10:49 PM
EFI-Unlimited's Avatar
Does this car already have a chip installed? If you say no, have you personally seen the back of the PCM to confirm this? If not, a 10mm and a 5/32 socket will get you there in a few minutes to be sure.
That is one of the very few things that can cause that to happen.
Brian
EFI-Unlimited
Old May 26, 2009 | 04:48 AM
Zman's Avatar
I gota Cheby
no chip, this car is pretty much stock. just h pipe, and flowmasters
