F150 posi question
Old May 19, 2009 | 02:53 PM
blacksheep-1's Avatar
Default F150 posi question
Since I have about a dozen 8.8 posis lying around I wondered if one would fit my 97 F150?
I've been wanting to do that for awhile, anyone done this before?
Old May 19, 2009 | 03:07 PM
redneck222269's Avatar
the center chunk should be the same as long as yours is a 8.8. but not positive
Old May 19, 2009 | 03:25 PM
shinysideup's Avatar
TR Balla Donor Supreme
both 8.8's , so if the f150 has 28 spline as well its all good.
Old May 19, 2009 | 03:31 PM
$hawn's Avatar
lives in a glass house
all the truck 8.8s have an extra wheel attached to run the speedometer.
if your truck is a 5.4 it should also have a 9.75 ring gear...
Old May 19, 2009 | 06:16 PM
No the truck is a 4.6, but what's with the speedo-wheel? Does it unbolt and can it be exchanged with the posi unit?
Old May 20, 2009 | 03:38 AM
$hawn's Avatar
it sort of looks like an ABS ring found on an axle but bigger. it presses on the differential. I not sure if the car 8.8 has the extra machined grove to press it on??
Old May 20, 2009 | 08:33 AM
OK, but it's on the axle right?, all I'm going to do is swap in the posi unit.
Pop out the axles, pull out the old dif, exchange the ring gear and reset the backlash on the posi unit and put it all back together.
Old May 20, 2009 | 12:30 PM
$hawn's Avatar
no. its on the differential, like this.....
IIRC its 31 splined also
Old May 20, 2009 | 06:02 PM
HHhhhmmmmm..........................
That would throw a turd in the punchbowl
