need help
i dont know about the heat but the gap i would have to say just start at like 40 or so and just keep adjusting them till you find what works best.
its ok, the more parts that fall of the lighter i get.
What issues are you having with the car now? Any ignition upgrades?
General Stonewall Jackson has been quoted saying that when the time of war comes,
“My advice is to draw the sword and throw away the scabbard".
Dont want too hot of plugs as it will cause detonation under boost but they have to be gapped close enough to ignite the A/F mixture under boost so closer than factory tolerances depending on the ignition system. If you have a higher power coil then you should be able to gap them wider.
(USER WAS BANNED FOR THIS POST)
