PROBE!!... HELP plz..
Old May 5, 2009 | 03:13 PM
moshman1205's Avatar
Default PROBE!!... HELP plz..
I have a ford probe. its a 2.0 and i thought i needed a fuel pump but i put a new one in and its not doing anything, acting like its not getting power to it at all. the relays click under the hood but the pump doesnt wine, not even when its turning over. ANY IDEAS THOUGHTS at all?? Thanks Devin
Old May 5, 2009 | 05:06 PM
Joker Instituted's Avatar
wanna be ford guy.
my 98 excort had a 2.0 in it, not sure if it relates but. there was a fuel cut off switch (factory) on the driver side in between the door and under the dash. maybe you have one on the probe somewhere and it some how got triggered?
its ok, the more parts that fall of the lighter i get.
Old May 5, 2009 | 05:20 PM
true, i never thought about that man. thanks ill go check it out and see if that was the problem this whole time..
Old May 5, 2009 | 05:28 PM
wanna be ford guy.
if its not then only otheer thing i can think of is to put a test light to it.
Old May 5, 2009 | 09:37 PM
i put the tank back up and i hear the fuel pump whine but it doesnt start.. yes there is gas in it... any input?? it does start with starter fluid..
Old May 6, 2009 | 02:09 AM
GNs-r-slow's Avatar
Bondsman
Take line loose before filter and see if you have fuel pressure. If you have fuel there, check filter for clog. If filter is clear, diconnect return and check pressure there. If you have no pressure before filter check voltage at the tank to be sure you have enough voltage to run pump properly. If pump is new and its not as loud as it should be, I'd start with the voltage check
Old May 6, 2009 | 09:07 AM
it was a clogged fuel filter... all better now.. thanks buddy for the advice.
Old May 6, 2009 | 11:29 AM
bvh's Avatar
bvh
i hate when that happens ...
Old May 6, 2009 | 03:07 PM
GNs-r-slow's Avatar
Bondsman
NP, glad you got it going
