sn95 dash in a fox body
Old May 2, 2009 | 04:03 AM
91EF-9's Avatar
is tired
Default sn95 dash in a fox body
ive been reading up on the conversion has anyone here done it? i think i want to put one in my coupe id also like to do the door panels if anyone could give me some info or tips id appriciate it greatly thanks -Josh
bucs2superbowl03@yahoo.com
Old May 2, 2009 | 08:00 AM
Joker Instituted's Avatar
wanna be ford guy.
pshull727 (paul) said he has done this. you might want to give him a shout.
there was someone else on here that did the whole inter. swap but i dont remember his name.
its ok, the more parts that fall of the lighter i get.
Old May 2, 2009 | 09:47 AM
Pshull727's Avatar
yeah i swapped in a 96 cobra dash and center console in my 89 coupe and im working on the door panels at work this is alot of work and can not be done without a welding and if you dont know how to do wiring this may not be something you want to start there is a lot of rewiring to do and you need a full sn95 dash harness and a fox harness and if your going to get the sn95 gauges to work you need to run vss wires for the speedo i can post some pics after work.pm me if you need to know something
2008 Acura TL DD
1998 Beater Ranger DD
1994 Ford Mustang Project
Old May 2, 2009 | 11:50 AM
racingrick's Avatar
POTENTIALLY FAST
I think there's a how to on the corral if you do a search there. I've seen it a few times at car shows and wish I could do it, I would, I already have sn 95 leather in my coupe.
Old May 2, 2009 | 12:37 PM
Pshull727's Avatar
its not that hard but a welder and some time is needed if i was to do it again i would use a 2001-up dash
2008 Acura TL DD
Old May 2, 2009 | 05:11 PM
91EF-9's Avatar
is tired
ok thanks! im not to serious about it yet im not sure if i want to delay my project any longer but im thinking about it and if i decide to go ahead and do it ill let you know thanks again
Old May 2, 2009 | 05:13 PM
91EF-9's Avatar
is tired
yea i googled it and i ended up at corral but they didnt go into full detail...
Old May 2, 2009 | 06:48 PM
Hurstmeister's Avatar
Theres several ways of doing the SN95 dash into the fox. You can just mount it for the look and feel with nothing functional using aftermarket gauges and such. That would be a quickest and easiest route. Or you can do it like Pshull727 is doing,.. making everything functional and look exactly like it would if you were sitting inside an SN95 car.
I miss the SN95 dash a little bit. A lot less creaks and groans then a fox dash. But I like the fox setup too.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old May 2, 2009 | 08:09 PM
91EF-9's Avatar
is tired
thats my problem i like them both but i would want everything functional in the sn95 dash
Old May 2, 2009 | 08:43 PM
Pshull727's Avatar
i got everything working in my swap after all the work to get the a/c working im removing it from the car lol but all the stock sn95 gauges work(you will need a 94-95 5.0 custer or 94-98 v6 custer for the tach to work right) and the wiring is not that bad but does take alot of time but you can get everything to work and look like sn95 with a lil thinking.But like i said i would try to get a 2001-2004 dash as they have no clock and the bigger radio opening(great for nav units) but if you want black you will need to find 94-98 dash.
2008 Acura TL DD
