3g alternator upgrade worth it?
thinking about upgrading my alternator - i can get 100amp alternators from summit for cheap ($100). i think 100a would be plenty (89 fox convertible)
anyone want to convince me that i need the 3g?
200 points away from a 300
I dont see why you would have a problem running the 100A alt but heres a good read about the differences.
The Corral Tech
Personally I would go with the 3g just for the better connectors and alt life.
The Corral Tech
(USER WAS BANNED FOR THIS POST)
Depends on the "draw" of you system. Stereo, underdrive pullys, big fuel pump(s), electric fan(s), nitrous, trunck mounted baterry(s). If you car is stock, a stock alternator does fine. When you start adding extra power is only when you need to upgrade. If you upgrade alternator dont forget about the bigger feed wires that are often overlooked
3G all the way, the upgraded wiring and less risk of fires from burnt up alternator connectors is the best reason
"Genuine" ASE certified Mazda, Hyundai, Isuzu Technician
Escort Enthusiast Site
Automotive Electrical Specialist, Tuning Specialist
So are you asking if you should go with either the Summit $100 deal or the 3G?
I know summit sells those one wire (chevy style) alternators pretty cheap but I wouldn't suggest them. 3G all the way!!
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
Our shop can build a high amp 3g alternator too
looks like i will go 3g
