hood scope question
Old Apr 10, 2009 | 06:03 PM
Joker Instituted's Avatar
wanna be ford guy.
Default hood scope question
how is a forward facing hood scope set up.
also what is the reason for having a reverse scope?
im sure that i will be having a clearence issue seeing that the performer sit's up a little higher then the stock one that was on there, and the space plate is almost twice the size of the egr plate. adding this to the holley 600 and the little triangle POS air cleaner that i have im sure something willbe hitting the hood when closed.
so i was thinking since the chassie itself is just a beater body for the most part and the hood is all dented up i might as well just cut a hole in the hood and put on a cheap little scope.
but how would a forward facing scope work while driving in the rain?
and whats the purpose of it being reversed if its not bringing in air?
its ok, the more parts that fall of the lighter i get.
Old Apr 10, 2009 | 06:08 PM
5pOiNtSLOW's Avatar
No.
Just get a cowl hood that clears the motor components.... hood scoops, especially the old standard Snorkel and the newer aero style belong on real race cars, not hacked up street cars..... it's the Fast and Furious equivalent to a 2 foot tall wing on a Toyota Yaris. Do not do it.
Cowl hood all day, every day.
Old Apr 10, 2009 | 06:14 PM
wanna be ford guy.
if i had the money or the chassie then yeah i would buy a new hood. im not doing it to be riicy im doing this for carb and air cleaner clearence. and if someone wants to laugh about a hagerd looking stang then let them laugh i'll laugh with them if it makes them feel any bigger about themselfs.
Old Apr 10, 2009 | 06:49 PM
Stealth Mode's Avatar
Still CREEPIN
just ask mikey, capri scoops are pimp(backwards) lol.
TurboRAM Member #5
24psi & Stable
GET SOME
Old Apr 10, 2009 | 06:51 PM
Still CREEPIN
u consider mid 80s capri's "real race cars"? his car isnt hacked up either.
TurboRAM Member #5
24psi & Stable
GET SOME
Old Apr 10, 2009 | 07:30 PM
racingrick's Avatar
POTENTIALLY FAST
scope kills the germs that kill bad breath.
however, some people believe that having a forward facing scoop forces air into the induction system (ram air), helping horsepower.
I've always understood the reason for the cowl hood is the forward facing SCOOP has too much turbulence and makes it hard to tune the car, the cool air at the base of the windshield (cowl) is easier to draw into the engine compartment to feed the motor.
Old Apr 10, 2009 | 07:31 PM
wanna be ford guy.
i would not want to waste something good on my hood. but who knows i might not even have to worry about things clearing. but if so im just gonna cut a hole and put on a cheap little cowl or scoop.
Old Apr 10, 2009 | 07:32 PM
wanna be ford guy.
^^ so the cowl hoods act like a vacume or something?
and i didnt think a foward facing SCOOP would add horsepower, but maybe a bit cooler running temp more then anything.
Old Apr 10, 2009 | 07:36 PM
DrDirt's Avatar
Team Geritol Racing
I have a fondness for bassackwards Capri scoops.
The cowl hoods and rearward facing scoops are able to suck in air because, at speed, there is a low pressure area generated at the base of the windshield which happens to be right where the opening is. Air flows from high pressure to low pressure. Ta Da!! Your underhood area sucks.
YO! Barry! You LOST!
Old Apr 10, 2009 | 07:41 PM
wanna be ford guy.
ok so i guess the cowl hood wins then. anyone have a cheap one?
