Still having hot restart issues...
Ok so it's been months and I haven't figured it out yet. I haven't spent much time maybe 2 hours total actually diagnosing
since it's a weekender and not a daily driver but here's the situation.
1986 Mustang GT T-Top
Starts up cold perfect.
Once it gets up to temp won't restart, acts flooded
Compression is good 165+ all across when hot
I Unplug the fuel pump relay and spin her over for a few seconds and she starts right up with a puff of black smoke like she's flooded
I didn't know the age and condition of the fuel injectors so I put a new rebuilt and bench flowed set in there. The car runs much smoother, but the problem is still there.
New parts fuel/ignition related
MSD Cap
Rotor
Ignition Module
Fuel Pump (255lph)
Fuel Filter
Ford 24lb Fuel Injectors
it's a 24lb MAF converted system with a pro-m calibrated MAF Cobra upper and lower intake and not much else
Any ideas?
since it's a weekender and not a daily driver but here's the situation. 1986 Mustang GT T-Top
MSD Cap
Rotor
Ignition Module
Fuel Pump (255lph)
Fuel Filter
Any ideas?
"Genuine" ASE certified Mazda, Hyundai, Isuzu Technician
Escort Enthusiast Site
Automotive Electrical Specialist, Tuning Specialist
I was getting a leakdown before I changed out the injectors. Just put those in this afternoon after work so I will check my fuel pressure tomorrow after work. Like I said it's just a cruiser so I don't stress about it too much just work on it when I feel like it
I have a 5.8 truck Adjustable pressure regulator floating around somewhere. It looks like the same bolt pattern and line size as the 302. Anyone know if that will work ?
. I have a 5.8 truck Adjustable pressure regulator floating around somewhere. It looks like the same bolt pattern and line size as the 302. Anyone know if that will work ?
A leakdown meaning checking the fuel pressure and watching the gauge do down with the koeo
Clamp off the return line with a pair of Vise grips and the turn key on to pressurize. If it holds pressure throw away regulator and replace with a good one. If pressure still drops time to check injectors and check valve in pump
I hope it's not the injectors or the pump...they both are new
I'll keep you guys posted on my further diagnosis once I actually dig into it
