Carburetor questions
So, I am another one of those swapping in a carb and going away from efi.
Basically, the question for me is spread bore or square bore.... The choke is gonna be mechanical, but what is a "Ford Kickdown"?
See this ad for what I'm leaning towards, it's a square bore (yeah, I do more street driving that strip driving but I want the best all out-performance when I need it)... the options on this one say Ford Kickdown: no
Shed some light? Thanks.
Holley 0-4777C - Holley Model 4150 Carburetors
On the Ford kickdown, this is for the transmission. If you're running a manual trans, you don't need the Ford kickdown. However, if you're running an automatic, then you likely WILL need one.
if im not mistaken, a kickdown has to do with an auto trans. and if this is true then if your running a 5speed then you do not need a kick down.
its ok, the more parts that fall of the lighter i get.
LOL @ New Hampshire.... it's Australia dude.
So, I get the spreadbore vs. Squarebore... Now I get the kickdown gimmick. I have a manual so I don't need the kickdown.
Thanks.
(Stephan is a smartass)..... hahaha
Thanks.
