balance question ...
Old Feb 5, 2009 | 04:39 PM
FordRacing101's Avatar
Default balance question ...
hey i have a question when i ordered my crank they asked me which damper to use its a 5.0 5spd... i said 28.2 i think thats right for manual but i need a 28.2 flywheel and what harmonic to use help me out guys makin sure everythings righ b4 i get it in the car
Old Feb 5, 2009 | 05:29 PM
shinysideup's Avatar
TR Balla Donor Supreme
Most 5.0 use a 50 oz. inbalance.
Your engine doesnt care what trans is mated to it.
Old Feb 5, 2009 | 05:39 PM
so your saying inbalance u mean crankshaft damper ? im still unclear my crank has a 28.2 oz damper on it if i add the flywheel = more weight on that side since the fly bolts to the damper which harmonic or flywheel do i run i am unsure if it even matters?
Old Feb 5, 2009 | 05:44 PM
Tiffiny's Avatar
I can fix your bullshit
If you ordered something from someone they should know what goes with what.maybe you should get a new parts place....
28 is usually 4 a stroker
Old Feb 5, 2009 | 06:09 PM
You're so lost, where do we start......
How about a complete rundown of exactly what you have and where you are going with it?
Old Feb 5, 2009 | 10:16 PM
Hurstmeister's Avatar
In a month or so I will be going through the same thing,.. and gonna need some experienced advice except for a 351.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old Feb 5, 2009 | 11:05 PM
BigDawg's Avatar
has his prioritys ef'd up
Hurst
With a stroker, you have the choice of the 28 oz, but some opt for the neutral (0) balance.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old Feb 6, 2009 | 12:48 AM
hey man just tryin not to rip apart my motor .. i have a .30 302 - full probe rotating assembly they put a 28.2 oz damper on the crank i just want to make as close to 500 whp as possible without splitting the block single turbo ect ect .. running 5 spd just a little confused on where to go next
Old Feb 7, 2009 | 04:11 AM
T/S #25's Avatar
Need To Get Quicker
If they put a 28oz balancer on it, then you need to go with a 28oz flywheel. Once you get that, take it to your local machine shop, have him spin it up, and make sure that the balance job is spot on.
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
Old Feb 7, 2009 | 09:57 AM
351coupe's Avatar
refinish artist
+1,You can get any balance you want on a motor.351's are 28oz,older were 50oz.,302's are 50oz.On a new motor,the lower the balance 50,28,0 the less there is to dampen.Less wieght on the ends of the motor=less vibration,smoother reving motor.
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
