Advice on a window motor?
Old Feb 1, 2009 | 04:20 PM
Black_notch's Avatar
Default Advice on a window motor?
Drivers side window has started acting up, just before it gets to the top the window gts stuck and you can hear the window gear sound like its "slipping" yo hear a knock, knock, knock sound coming from the window motor. Pulled the panel odf and looked at it and the white cover thats facing me on the motor has a half circle crack and its flexing outward once the glass gets to the top and starts making that sound.
Just wondering anyones got changed these out before, the chilton's talks about removing the glass and sh$t and it seemes like I didnt have to do all that trash on my 95 I had.
Any thoughts? Thanks!
1995 Black on Black Cobra- waiting to awake.
Old Feb 1, 2009 | 06:24 PM
n8secstangg's Avatar
mormally those symptoms are resulting from the 3 plastic gear pieces in the gear assembly in the motor going bad, napa sells a kit for them
www.racinginnovationsfl.com
www.xsrcylinderheads.com
4.842@156 and 7.53@192 on radials
Old Feb 1, 2009 | 06:27 PM
10-4, thats been my experience as well. I picked up the bushings but noticed the outer case cracked on the window motor.
Old Feb 1, 2009 | 07:19 PM
GNs-r-slow's Avatar
Bondsman
They tell you to pull window for safety, I just wedge it in the frame
Old Feb 1, 2009 | 07:34 PM
Mars_302's Avatar
Race Photographer
yup plastic bushings. but sometimes w;ve repalced the bushings and after a month they got deformed again.
Old Feb 2, 2009 | 01:09 AM
smokeshow's Avatar
Slower Than Dial-up...
Post pics if you can..
Old Feb 2, 2009 | 08:55 AM
Will do guys, I just cant figure out how to get the damn motor out!!!!!!
Old Feb 2, 2009 | 03:35 PM
options2rx7's Avatar
i changed my driver side window motor about a month ago. what really sucks is that you really can't see what the heck your doing. but i removed the door speaker and removed the 3 screws holding the motor in place and fed it out through the speaker mounting hole in the door.
insert something witty here
