HEI Distributor
Old Nov 25, 2008 | 06:49 AM
byondevl's Avatar
Made Of Scars
Default HEI Distributor
I got a 351c HEI distributor. Will the duraspark ignition box work with the HEI? I had budgeted in for a new ignition box, but if I dont need to, then that $$$ can go to my headers.
Old Nov 25, 2008 | 07:47 AM
Na306StAnG's Avatar
Flowmaster nut swinger
It looks like this? Then no you won't have to run any kind of external box. Its a one wire setup. But just know that most of those setups are only good to around 5,500 RPMS. keep that in mind if you plan on the motor spinning any higher.
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Nov 28, 2008 | 08:49 AM
Joker Instituted's Avatar
wanna be ford guy.
i have an hei on my 302 rollor and a street fire ignition box hooked up. works nice and no over rev. a little confussing when hooking it up though.
its ok, the more parts that fall of the lighter i get.
