t5 question..
Old Nov 21, 2008 | 03:38 PM
mikiemike75's Avatar
mikiemike75
yeah a 4cyl will work... you can also use a 99+tranny and even the ranger t5 also the camareo tranny will work but you have to swap the tail shaft...
Built By:Mike Carpenter @ Overdose Performance in Ocala,Fl...
Tuned By: Tony Gannon @ Hp Performance
hp~5!! trq-4!!
doing work!!!!!!
Old Nov 21, 2008 | 04:18 PM
Mars_302's Avatar
Race Photographer
96+ do not work, neither will the camaro. You can use the v6 mustang trannys though
Jason.'s Avatar
I know a 4cyl t5 will work in a fox, becuase I've used them before.. But on an sn95, slong as I swap the bellhousing can I bolt a 4cyl t5 up with no other changes?
2011 Kia Optima SX Premium/Touring package
Old Nov 21, 2008 | 04:34 PM
racingrick's Avatar
POTENTIALLY FAST
will work fine, it's 3/8 inch shorter, i've done it, you have plenty of extra length on driveshaft to account for it unless your car has been lengthened!!! LOL
4 cyl will work fine also, weaker, lower first gear, have to change the pilot bearing use a ranger diesel 4 cylinder bearing, works fine, pilot bearing can be a bitch to change.
