Pinging Noise From Engine!
Wtf is its prob? Could it be the fuel acting up. Cheap ass gas? wtf this is pissing me off! help!!
2004 GT: STOCK
1997 GT: Mods: 180 Degree Thermostat, Flowmaster 2 Chambers, MAC O/R H Pipe, MAC Cold Air Intake w/K&N Filter, 75mm Ported Upper Intake w/ 75mm BBK Throttle Body, Screamin Demon Coils with Livewires
1997 GT: has front end damage still drives FOR SALE
AIM:OmFgStFu
2004 GT: STOCK
AIM:OmFgStFu
I just checked in my handle repair manual I got some shit to find
but any of this happen to you? F-O-R-D Found On Road Dead so true some day..
2004 GT: STOCK
AIM:OmFgStFu
2004 GT: STOCK
AIM:OmFgStFu
When I took it in it never threw a code they said it was still running as new. I never played with the factory settings either I dunno how to.
2004 GT: STOCK
AIM:OmFgStFu
2004 GT: STOCK
AIM:OmFgStFu
Mike I bet its because we forgot to take off the -ve cable on the battery so it would reset itself! lol but one prob the -ve is stripped but I dunno how Sears took it off before because it was stripped! So im gonna go bitch at sears and tell them to put on some new cables.
I need them.
I need them.
2004 GT: STOCK
AIM:OmFgStFu
2004 GT: STOCK
AIM:OmFgStFu
you dont have to take off the negative for the computer to reset only the positive.....are you sure its a ping and not some kind of rattle....??
200 points away from a 300
Oh ya Im such a dumbass It only happens at higher rpms like around 4000-6000rpms. Maybe a rattle maybe the rockers?
2004 GT: STOCK
AIM:OmFgStFu
2004 GT: STOCK
AIM:OmFgStFu
If it only happens at high rpms its a fuel problem. If you go to ford make them go for a ride with you so they can hear the problem rather then just trying to explain it most of the time they are just lazy and try to take the easiest route and it doesnt fix the problem.
Guest
Posts: n/a
If it was rockers you would hear it at all rpms. If it is happening between 4000-6000 rpms then Mike is probably right with the fuel starvation. It can be a number of possible things anything from some cheap sensor that just went bad to a clogged injector that is letting one of the cylinders go lean.
If you want to get a idea of what is wrong go drive the car for a little bit in the rpm range that is causing the problems then go home and pull the spark plugs to see if any of them are white which would be lean. Do not idle the car long when you get back from your drive this way the plugs do not have time to change much. Then let us know.
