Got a slight Prob
Old Oct 27, 2008 | 12:56 AM
smokeshow's Avatar
Slower Than Dial-up...
Have you put your car on independent scales? Where it measures the weight on each wheel? Your weight displacement might be off...
Old Oct 27, 2008 | 03:50 AM
Zman's Avatar
I gota Cheby
is your front sway bar on?
def need air bag in pass side rear.
possibly tires are too short and not letting the suspension work.
taller tire will have a better footprint but also absorb some of the shock and it lets the suspension work better on the initial hit.
Only 1/4 mile track I know is Gandy Bridge
Old Oct 27, 2008 | 05:39 AM
Shamus O'Toole's Avatar
Redneck Yatchclub member
Set your pinion at -2 degrees. Slicks or radials? Suspension setup is differant depending on what tire your running.
Old Oct 27, 2008 | 06:21 AM
95coBraSVT's Avatar
banana republic
Put in a motor with less horsepower. V-6's get decent mileage too. Problem solved.
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Oct 27, 2008 | 08:43 PM
Domiann's Avatar
Pro 5.0
im running slicks
Old Oct 28, 2008 | 05:48 AM
Tiffiny's Avatar
I can fix your bullshit
need bigger slick
Old Oct 28, 2008 | 03:58 PM
  #17 (permalink)
T/S #25's Avatar
Need To Get Quicker
Do you have a trans-brake or are you leaving off the foot brake?
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
Old Oct 28, 2008 | 08:23 PM
  #18 (permalink)
Domiann's Avatar
Pro 5.0
ive got a trans brake and leaveing off foot brake gunna test somethings out weds at the sunshine hope it helps
Old Oct 29, 2008 | 06:51 PM
  #19 (permalink)
Domiann's Avatar
Pro 5.0
ok hooking ok but spinning in 1st still (60') 1.650 (330') 4.657 (1/ 7.211 (mph) 96.37 frist run last run added some lbs in the back and let air to 10 (60') 1.594 (330') 4.628 (1/ 7.206 (mph) 95.55 http://www.youtube.com/v/hgCjFaIsGJo
Old Oct 29, 2008 | 09:22 PM
  #20 (permalink)
Badlatitude's Avatar
bbbblllllaaaaaaahhhhhhhh
**********************THE BEST Upper Control Arm Kit on the market********************** read all of theese articles. pring them out and you will know whats actually happening when you launch your car and how to adjust it
