New clutch cable, firewall adjuster and quadrant
Old Oct 18, 2008 | 07:23 AM
**CHRIS**'s Avatar
Called the amba lamps
Default New clutch cable, firewall adjuster and quadrant
I've installed all of these within 30-45 minutes in my driveway but can't quite get the pedal to feel normal yet.....
There is a lot of play in the pedal and after pushing it, it feels very tight. It works fine though on a test drive.... just not perfect.
On the firewall adjuster, is it more threads showing means a more pulled up pedal (no play)?
Forgive my ignorance... never had one of these, always did it from underneath the car.
halp.
Old Oct 18, 2008 | 07:39 AM
**CHRIS**'s Avatar
I think I got it... it's at least better than it was.....
Shaun, I might stop by just to bullshit anyways.... been a while.
Old Oct 18, 2008 | 05:01 PM
SVTd's Avatar
I installed my fiore FW adjuster and quadrant but also installed a spec 3+ clutch. When I adjusted the firewall adjuster all the way out the clutch was engaging when the pedal was barely off the floor. So, I unhooked the cable and I put the rubber grommet back on between the adjuster and the cable and got it adjusted with the way I wanted it. The cable may have stretched slightly.
