t-bird axles
Old Oct 7, 2008 | 12:16 PM
blacksheep-1's Avatar
Default t-bird axles
I have an 8.8 limited slip out of a turbo t-bird, I need to find some 5 lug axles and brake rotors to fit this rear.
What would interchange?
Thanks
Old Oct 7, 2008 | 12:21 PM
GNs-r-slow's Avatar
Bondsman
i have some new US alloy axles that will work 5 lug hardened with bearings, seals ane studs $175
Old Oct 7, 2008 | 02:37 PM
svojohn's Avatar
Half an Engine
I'm interested if he doesn't come through. Let me know.
John
Old Oct 7, 2008 | 05:36 PM
I just popped for some coil overs, go ahead and sell them. What were they out of?
Old Oct 7, 2008 | 05:39 PM
GNs-r-slow's Avatar
Bondsman
the box, theyre new
Old Oct 7, 2008 | 06:10 PM
shinysideup's Avatar
TR Balla Donor Supreme
Bird axles are wider than fox?
Old Oct 7, 2008 | 06:25 PM
GNs-r-slow's Avatar
Bondsman
disc brake 3/4"
Old Oct 8, 2008 | 05:33 AM
Tiffiny's Avatar
I can fix your bullshit
you can use sn 95 axles same size but i would just get the t bird rotors drilled for 5 lug other wise your opening a can of worms trust me i did it to my car
Old Oct 8, 2008 | 02:54 PM
Just Dave's Avatar
Do It In The Dirt
There aren't any other calipers or rotors that interchange with TC stuff. You could cut the caliper brackets off (they are welded to the axle tubes) and then its just an 8.8 housing, you can add whatever you'd like.
29 Hard and Single
My Rail Buggy
