Question about rod knock
Had a friend of mine give me a Toyota Camry if I could get it running. It had been sitting for two years. Long story short, got it running but it has a loudish ticking/knock sound. It is present at about 2krpm up to 3k and then fades away upwards of 3500. At idle it is present but very faint. Car runs fine and idle is smooth other than the noise nothing seems wrong with the car. Does this sound like rod knock to you guys or could this be noisy sticky two year gunk lifters? I have never experienced rod knock so.... I did change the oil immediately after I got it running and added a quart of the Marvel mystery stuff. I just dont want to start driving it to Tampa everyday and have it blow a rod out of the block on the upper crosstown ya know
Thanks for any help
Thanks for any help
if it looks like a duck, walks like a duck, quacks like a duck..............
it's OHC correct? it should have some kind of cam follower not a lifter like a push rod engine. Rod knocks don't usually get quieter with more RPM, they get worse.
take a piece of pvc pipe and hold it your ear then different parts of the motor. At least this way you can sorta pin point where the sound is coming from. If its sounds more like the block it might be a rod knock, the head, then its valve train. Though it sounds mor elike top end noise. Id drive it aorunda but for while and see if it bleeds out
