Identifying Wel Rims?
Old Aug 31, 2008 | 01:36 PM
69Boss521's Avatar
PORK CHOP SAMICHES!!!!!
Default Identifying Wel Rims?
I have weld rims that came with the coupe that are on the car. How can I tell what the backspacing is along with the width of the skinnies up front and the ones out back. Only #'s onthe back are 17-93 and on the fronts are 23-97
Derp!
Old Aug 31, 2008 | 01:50 PM
Zman's Avatar
I gota Cheby
just by looking at the rears in your pics they are either 15x7 or 15x8 with 4 1/2 rear back spacing. The 5 1/2 rear back spacing have less of a outside lip. the pic I see you have an outer edge lip. Now you can just take them off also and measure them.
Only 1/4 mile track I know is Gandy Bridge
Old Aug 31, 2008 | 02:49 PM
69Boss521's Avatar
Thanks Andel. I was hoping Welds have some # on them to identify them. The fronts are either 4 or 5 inch wide, can't tell. The backs have 265's on them. There is about an inch to an inch and a half between the tire and the inner fender on the rears.
Derp!
Old Aug 31, 2008 | 05:08 PM
shinysideup's Avatar
TR Balla Donor Supreme
You need to remove them to measure BS, many sites will show how.
Old Aug 31, 2008 | 07:59 PM
Badlatitude's Avatar
bbbblllllaaaaaaahhhhhhhh
lay a machinists ruler across the back of the rim then use another to go from the INSIDE of the bolt face ( part that goes against the brake drum or rotor) ... u found your back spacing ... as for the width of the wheel itself with a tire on its kinds annoying just use a square small enough and a straight edge... Its not like we are talking rocket science here
Old Sep 1, 2008 | 05:13 AM
69Boss521's Avatar
I know all this fellas. Was just trying to avoid yanking them off.
Derp!
Old Sep 2, 2008 | 10:48 AM
Stealth Mode's Avatar
Still CREEPIN
lazy ass mofucker, lol jk. TAKE EM OFF, BE SURE!!!
TurboRAM Member #5
24psi & Stable
GET SOME
Old Sep 2, 2008 | 08:37 PM
ChrisN1313's Avatar
the numbers stamped on the front of weld wheels mean nothing on there size or part number etc.
