gears?
i have a 3:73 also--i still get good gas mielage--actually alot of people go with a 4:10 on the modulars but id get a 3:73 over a 3:55 if your super worried about highway travel then just go with a 3:27 but it probably not worth the money to geat a 3:27....at 90mph i rev at 3000rpm and still get good mielage....the mod motors dont seem to mind high revving...
200 points away from a 300
Guest
Posts: n/a
Do you have a automatic or 5-speed ? You should go one set higher for a automatic because of the way the trans. is geared. Therefore a 3:73 on a auto. is the same as a 3:55 on a stick. If you have a auto go with the 3:73 to keep from having all of your power right out of the hole and go with a 3:55 on a stick for the same reason. 4:10s are to high on either car unless you have gumdrops for tires. Hope that helps.
My vote would be for the 3.73s as well...
I only get about 16-17MPG... but that didnt change that much from the stock gears.
Speaking of which... Ive been running with the original speedo gear in there since... anyone have any experience with the compensators?
- Fae
http://www.faethorstack.com/freedom/freedom.html
- Fae
The Iron(FE)-Works
My daddy always said, "When you want to hammer a nail, don't do anything fancy. Just get a hammer and pound the son of a bitch."
The Iron(FE)-Works
