electrical question
Old Aug 23, 2008 | 01:08 PM
gray89gt's Avatar
Default electrical question
I have an 89 gt. I parked it before our storm this week. and everything was fine. went out friday and cranked it up and the amp gauge was pegged at 18 amps. if i turned the lights on it would drop down a bit but still way to high. is there a voltage reg. on these cars or what else would cause this. I'm kinda new to stangs but thought i would tap into the knowledge of everybody here before i start tearing apart stuff.
Old Aug 23, 2008 | 02:43 PM
Graves's Avatar
sounds like what mine did when the alternator went out. check the plug on the alternator and the fuseable link by the solenoid.
Old Aug 23, 2008 | 03:16 PM
95coBraSVT's Avatar
banana republic
It's internally regulated. The alt needs rebuilt/replaced.
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Aug 23, 2008 | 03:50 PM
gray89gt's Avatar
I appreciate the info. at least i have a starting point. I will check the plugs and then pull it off and go to the parts store and get a test on it. thanks alot guys.
Old Aug 23, 2008 | 06:19 PM
Graves's Avatar
and if you replace it get a new plug.
Old Aug 23, 2008 | 07:00 PM
Joker Instituted's Avatar
wanna be ford guy.
if for some reason none of that works pm me. my mother can find any kind of short in a harness and can fix it if there is one.
its ok, the more parts that fall of the lighter i get.
Old Aug 25, 2008 | 08:01 AM
gray89gt's Avatar
well its not the alt. had it tested and it was working like it should. so now time to check the gauge and all wires.
