trying to decide on rear tires
Cars on stock suspension and running 16 inch ponies. Have 225\50\16 up front. Wanted to go wider in the rear, but everywhere I look I can't find a tire the same profile or larger in a 255. How big visibly is the 45 series compared to the 50?
Here's how to decode a tire
225= tread width in MM
50= percentage of width for sidewall height
16= rim diameter.
So basically your current tire is 225mm wide, and has a sidewall height of 112.5MM (50% of 225). A 255 45 would be 114.75MM. So it would be a couple of MM taller.
16= rim diameter.
go with then 50, its only an inch taller, or atleast thats what it is on my tires.
SUCH IS THE RULE OF HONOUR.
Well found a few options
Street tires:
Hankook Ventus V4 255\50\16
Falken Ziex 255\50\16
BFG G Force Sport 255\50\16
Drag radials but not sure if I want theses on a DD:
Nitto 555r 245\50\16
G-Force T/A Drag Radial 255\50\16
Mickey Thompson ET Street Radial 255\60\16
Almost tempted to get some 15" draglite rims since there is such a larger tire selection.
Street tires:
i have the gforce sports on my cars, Ive been very happy with them for daily use and handling.
I just use spare rims for slicks and drag radials. They make 28x10.5/16 drag radials and slicks which work perfect for me.
255/50 looks nice but only if you do it all the way around. Id do 245/45
