Question for a buddy doing a A9L swap into his '95
He tells me that he has a 93 cobra computer that he has plugged into his '95 GT and now the car will start and run, but when he turns the car off, it will continue to run.
I have searched the Corral to find alot of threads where users are telling guys to search and the info is out there. Well I come across terms like PIH and start researching to find out what that is and I have had no luck. I'm about to tell the guy that he's just out of luck.
Apparently, the general consensus seems to be, that the A9L swap is just okay, but takes a decent amount of work for little gain vs getting a chip burned for an application.
I know the guy won't ask a shop and will just work on making his A9L swap work. I just wanted to help him out if I could and if it doesn't get too involved, otherwise, Im'a have to start writing stuff down to pass on to him.
about a month ago............no limit performance off of peachtree street behind where tmec used to be.............just starting out so he's doing any thing for money right now, goal is mustang performance only.
93 cobras didnt use the a9L.
SUCH IS THE RULE OF HONOUR.
I am pretty sure that a 93 cobra computer was setup to run 24lb injectors with a 19lb mass air. I am not sure if he is aware of that, but something to think about.
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
I didn't catch cobra computer in original post (3 year old on lap) just saw A9L comment.
true, cobra's didn't use APL, don't recall what they used but to be honest you can really get more performance out of an A9P imo.
the automatic GT computer had more agressive spark and timing tables to try to make up for what a turd the car was. works great in a stick car.
obviously the best answer is to go with an aftermarket controller but an A9L or A9P is a very cost effective answer if you're not making a huge amount of horsepower. Nothing will take the place of a custom tune.
I ran 175 shot for 3 years in my95 with gt40p heads cut 20thousandths and only problem I ever had was before the computer swap, the factory fan controller went out after a hot day at Bradenton (about 10 passes) on the way home and I popped a head gasket. Then the fan worked fine, happened 2x before I figured out why and changed to the A9L and then no probs.
PIH? Thats not a term used in the Ford EEC.... PIP maybe what u are talking about. Profile Ignition Pickup.
If he does have a E3Z cobra ecm. Does he know its a good 1?....
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
