AOD flex plate question...
Old Jun 2, 2008 | 04:48 PM
IThaJokaI's Avatar
Hates cars...
Default AOD flex plate question...
Ok, my buddy has a 88 cougar with a 302 and AOD... He bought a 302 HO from another forum member, that came with a flex plate. He went to drop in the motor with the HO flex plate attached, but seems his TQ Converter does not match up with the Flex plate... Did they make different flex plates depending on year, or model? Like ho-non ho?
Thanks,
-Mike
Old Jun 2, 2008 | 05:13 PM
shinysideup's Avatar
TR Balla Donor Supreme
c4 or AOD. you need an aod. Iv got one but too far away.
Old Jun 2, 2008 | 05:49 PM
.Patrick.'s Avatar
Has twenty valves
its an AOD, the center of the torque converter is too big to slip in to the flex plate.
Old Jun 2, 2008 | 05:54 PM
IThaJokaI's Avatar
Hates cars...
^ truth
Old Jun 2, 2008 | 06:16 PM
Zman's Avatar
I gota Cheby
are you sure the converter is set back inside the tranny enough?
Only 1/4 mile track I know is Gandy Bridge
Old Jun 2, 2008 | 06:57 PM
.Patrick.'s Avatar
Has twenty valves
the engine came out of a car that had been swapped to a manual, so the pilot bearing was still there. thats why it wasnt going in. problem solved.
