2001 Ford excursion for Ford F250 engine swap
Old May 25, 2008 | 02:31 PM
iliketits99's Avatar
Thumbs down 2001 Ford excursion for Ford F250 engine swap
I'm looking to swap out my blown out motor for my 01' ford excursion to a ford f250 v-8. An uto salvage shop says they have a V-10 but i can't seem to find any on the web which is kind of crazy since it is the world wide web but any tips for the frankenstein creation to work?
2001 Ford Excursion XLT Utility Performance & Efficiency Standard Features
6,751 cc 6.8 liters 10 V engine with 90.2 mm bore, 105.7 mm stroke, 9 compression ratio, overhead cam and two valves per cylinder
Unleaded fuel
Multi-point injection fuel system
Main 167 liter unleaded fuel tank
Power: SAE and 231 kW , 310 HP @ 4,250 rpm; 425 ft lb , 576 Nm @ 3,250 rpm
2002 Ford F-250 Super Duty Regular Cab Pickup Performance & Efficiency Standard Features -
5,398 cc 5.4 liters 8 V engine with 90.2 mm bore, 105.7 mm stroke, 9 compression ratio, overhead cam and two valves per cylinder
Unleaded fuel
Main 110 liter unleaded fuel tank
Heavy duty alternator
Heavy duty battery
Power: SAE and 194 kW , 260 HP @ 4,500 rpm; 350 ft lb , 475 Nm @ 2,500 rpm
Old May 25, 2008 | 02:48 PM
Hater's Avatar
Free base cocaine
Ford Sections Thattaway ->
Old May 25, 2008 | 08:44 PM
Silvia_San's Avatar
Private Parts Thug Lyfe
throw it in the garbage?
Old May 25, 2008 | 08:57 PM
BlackWind's Avatar
Requiem
i worked on a v10 f250 at jarrett scott ford. They have them, and i dont know about the swap, but with enough money theres no reason it wouldnt work...and its not a frankenstein deal, its just a motor swap...
okay
Old May 25, 2008 | 09:33 PM
SayWhaa?'s Avatar
they call me baby Jesus
hope you dont like gas.
say whaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Old May 26, 2008 | 12:08 PM
_Charles_'s Avatar
formerly 'RiceRocket'
have you tried Car-Part.com--Used Auto Parts Market ??? they have several 5.4l V-8's listed from the F250 Super-Duty
My Blog: www.HotRodCaddy.com
Old May 26, 2008 | 02:05 PM
presidential's Avatar
OG Join Date: 6-15-00
Put a diesel in it and run it on fry grease.
1973 VW Squareback
1979 AMC Jeep Cherokee Chief
RIP Tim
Old May 26, 2008 | 02:29 PM
My Honda Is Slow's Avatar
No really,....it is
diesel would be the way to go. if your swapping engines anyways why not have a engine that you can actually get some decent power and better gas mileage than a gas engine?
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
