Front Calipers
Old May 12, 2008 | 09:06 AM
theTorinoguy's Avatar
Default Front Calipers
How hard is it to replace the front calipers on a 2001 Ford Mustang.....I took it to the shop and they said the rotor inside was oval not round like it should be and to fix both front calipers it would be $399.99. Should I get it done at the shop or would it be easier/cheaper to do it myself?
Old May 12, 2008 | 09:50 AM
Steve B's Avatar
brings his heater.
two 12 mm bolts and a brake line each side.
any tard bucket with a set of k mart tools can do a brake job.
Old May 12, 2008 | 10:00 AM
91Notch's Avatar
Is workin on his car
Seems a little high. Depends on how much he is charging you for parts. The hardest part about doing calipers is bleeding them. And all you need to do that is get a buddy to come help you.
Old May 12, 2008 | 06:33 PM
chevy eater's Avatar
+1 on the job not being that difficult,pretty straight forward job
Old May 12, 2008 | 07:28 PM
Zman's Avatar
I gota Cheby
heres a simple rule of thumb if its calipers. Inside pad worn or gone then Calipers are bad (not releasing), outside pad worn then its the sliders, hardware, Might need a little grease on contact points (calipers float and need to be able to slide back and forth), even wear then its just pads.
Only 1/4 mile track I know is Gandy Bridge
Old May 13, 2008 | 05:26 PM
S281-335's Avatar
For that price you could upgrade to Cobra brakes.
