removing gas lines
Old Mar 1, 2008 | 06:54 AM
Newguy07's Avatar
Default removing gas lines
How can I remove the gas lines from the frame of the mustang on the right side? I just don't wnat to weld while they are right there.
Please help. I can't seem to get the clips off from the frame.
Old Mar 1, 2008 | 07:55 AM
Mars_302's Avatar
Race Photographer
you are going to have a pain in the ass putting the fuel lines back on after you put the subframe connectors on
Old Mar 1, 2008 | 08:34 AM
Newguy07's Avatar
Why is that? The subframes won't block the fuel lines.. I am just moving them so I can weld...
Old Mar 1, 2008 | 08:39 AM
funford's Avatar
I never seen anything worthy of subframes that was still using stock fuel lines.
Old Mar 1, 2008 | 08:40 AM
Mars_302's Avatar
Race Photographer
the subframes go over the fuel lines I recall. So after you drop them outta the car you are going to have too fish them thru that little hole there you just made when you put the subframes up.
btw the lines are riveted to the body
Old Mar 1, 2008 | 09:34 AM
Newguy07's Avatar
not on my car..... I actually have the frame mounted already. It is tack welded in place. So there is no problem with the gas lines. I just want to weld onto the frame but the gas line is about 1" from where I want to weld. Therefore I want to move the lines because I am afraid of sparks hitting the line... I would rather have them at least 3-4" away.
Old Mar 1, 2008 | 10:39 AM
95coBraSVT's Avatar
banana republic
<----Ex welder.
I'll do it for you. Those are hard lines. Don't get the arc on the line, and you'll be fine. Basicly, don't put the wire on the line. You'll be fine.
I've welded on a gas tank before and had no problems. Of course, I removed it from the car, and filled it with water before attempting it, but it CAN be done. When the line is full is when it's the least volitile. Gas FUMES are flamable, not the liquid. Whats in the line? Liquid, not vapor (hopefully) Since it's a hard line, the sparks will bounce off and no problem.
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Mar 1, 2008 | 10:43 AM
Duceanahalf's Avatar
is doing your girlfriend
you can also put a flame retardent material over the line. i use pieces of leather since we have a bunch laying around
Old Mar 1, 2008 | 03:56 PM
91Notch's Avatar
Is workin on his car
Ok I don't agree with that statement and I am shure there are others here that will agree with me. Mustang chassis are weak and they need that added support. I have seen cars go deep into the 11's with stock fuel lines. Now 11's isn't blazingly fast but its nothing to shake a stick at. Moral of the story is any mustang that races on slicks should have sub frame connectors.
Old Mar 1, 2008 | 05:08 PM
95coBraSVT's Avatar
banana republic
This is true Dave....This is true.
