HELP: removing harmonic balancer
Old Jan 10, 2008 | 02:25 AM
OldMan's Avatar
Donut Killer
Originally Posted by Alan
I thought about buying one...but the budget just doesn't allow it right now.
If you lived closer, I'd just bring mine over.
If you don't get it figured out soon, let me know. I will bring it the next time I'm in Brandon.
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
Old Jan 11, 2008 | 05:15 AM
302andSome's Avatar
Originally Posted by mustangman101
also be carefull when you use the balancer remover tool. the pointed piece can get stuck in the end of your crank and damage threads. try to use the washer from the back of the balancer bolt and put it against the end of the crank where you just removed the bolt from. then the pointed piece can push against that instead. may need a hammer to get it loose so that it starts comming off.
Much safer to just use the flat end against the actual crank bolt, I've never used the pointed adapter directly on the end of a crank.
Where in Brandon you at? I'm off Providence if you need some help or tools.
Old Jan 11, 2008 | 09:28 AM
mustangman101's Avatar
89 2.3 91 SSP 5.0
no problem, hope it helped ya
